09-15-2020, 10:22 AM   #1
jumbleview's Avatar
Making the Photo of Colored LEDs
I need an advice. I am preparing tutorial of concurrent programming on Attiny85 chip. As an example I choose pumpkin glitter with colored eyes. There are two 10mm three-colored LEDS. Program changes LED color (There are 7 colors. Three pure colors: red, green, blue and four mixed colors, which are close to white, cyan, magenta and yellow). Before diving into programming details I would like to show the outcome: either a short movie or GIF made from static images. In real life colors look more or less OK but, when I try to photograph or film it, result is disappointing. There is almost no differentiating in colors, everything looks like glowing spots. I have attached iPhone photo as an example, tried DSLRs (Pentax K-5II, K-01 and Q-7) and did not see much difference. Is there any way to get reasonably good photos of colored LEDs?
IPhone 8  Photo
09-15-2020, 10:53 AM - 1 Like   #2
Haven't tried so I don't have personal experience but...
LEDs will be drastically brighter (severely overexposed) compared to everything else. I'd try:
1. Underexpose as much as possible. Pumpkin will be very dark but the LEDs will look better.
2. Get cheap & dark window tint from an auto parts store (or any dark film). Cut small circles (hole punch?) and cover the LEDs. Might need a couple layers. Basically trying to create a ND filter for the LEDs. Not certain if window tint will affect the color of the LEDs so that may create a different problem. Maybe there's ND film available somewhere?
---------- Post added 09-15-20 at 05:55 PM ----------
Google "neutral density gel sheet" and you'll find stuff. I guess I should have done that before responding.
09-15-2020, 10:55 AM - 1 Like   #3
Otis Memorial Pentaxian
This is not something I have tried, but my first approach would be to use supplemental light (flash or continuous) to balance against the very bright LEDs. I would also use fixed white balance shooting RAW and adjust both the white balance and color balance in post-processing. Including a gray card in a test shot may be helpful in this regard. You may need to adjust the eyes separate from the rest of the frame.
09-15-2020, 11:38 AM - 2 Likes   #4
photoptimist's Avatar
If you have access to the electronic circuit or programmatic control of the light's intensity, you could just dim the LEDs to match the brightness of the pumpkin area.
Or, as others have said you could try to boost the lighting - take the item out into full sunlight or use a flash.
In either case, the spot meter on your camera can be used to check the brightness of the illuminated pumpkin compared to the brightness of the lit LEDs. The LEDs can probably be a stop (or maybe up to 1.5 stops) brighter than the pumpkin and still show as bright color.
09-15-2020, 01:47 PM - 1 Like   #5
From somebody who likes to play with LEDs, this is the best, and perhaps really, the only way it's gonna work.
Note also that the light from the LEDs may be very pure in a wavelength sense - i.e. a red LED really puts out a very narrow wavelength band of red light. The color sensors in your camera sort of don't know what to do with this - there is overlapping sensitivity that varies by wavelength of the 3 color sensors.
09-15-2020, 01:50 PM - 2 Likes   #6
UncleVanya's Avatar
You could try to spot meter the led, undexposing the rest and then shoot an image without the LEDs illuminated and merge them in post.
09-15-2020, 01:54 PM - 1 Like   #7
QuoteOriginally posted by jspi Quote
Polarizer film would work (available on Ebay as thin film, or cheap clip-on sunglasses at the drugstore). Very little color effect, and you'll get about a stop per layer; with two layers you could vary the amount of cross-polarization loss - that's how variable density ND filters are made).
LEDs might be polarized, though - I'll take a look at that for my own curiosity!
09-15-2020, 03:12 PM - 4 Likes   #8
0 EV comp and light source bounced off a white mat board
09-15-2020, 03:32 PM - 1 Like   #9
jumbleview's Avatar
Thanks everybody for advises. I got the main point: strong external light, under-exposure, and post-processing. Not prefect but suites my need.
09-16-2020, 08:12 AM   #10
Wheatfield's Avatar
This is what I would do.
09-16-2020, 08:25 AM   #11
Hey, I like that!
5 Days Ago - 1 Like   #12
jumbleview's Avatar
Just to give this thread closing statement. I did publish project on Github and with your help there is the GIF image. It is not perfect but shows clearly how LED changes its colors. Thanks everybody especially jspi and photoptimist for the help.
GIF I made putting the pumpkin on full sun, making set of images (Pentax K-01 + Pentax limited 20-40 at 34mm on tripod, remote control, F22, ISO 100, Shutter 1/80, underexposure -1.0). Raw images I processed with Photoshop Element 2018. I busted whites by +50 and set temperature to 3000. The rest I did not touch. Here is GIthub link where you can see the final GIF: GitHub - jumbleview/pumpkin
The GIF I made out of 13 images and processed with site Animated GIF editor and GIF maker
camera, color, colors, film, leds, photo, photography, technique, window
LX LEDs hard to make out Gashlycrumb Pentax Film SLR Discussion 8 12-18-2019 03:02 PM
New ME F: the LEDS don't light up ummm Pentax Film SLR Discussion 9 02-08-2018 03:13 PM
K-20d Flashing red leds? Rich Roberts Troubleshooting and Beginner Help 4 08-23-2015 01:35 PM
K10d: AF-leds are not alligned in AF-frame jmbroekaert Troubleshooting and Beginner Help 5 10-17-2012 03:47 AM
Leds act so crazy on pentax me super toto123 Welcomes and Introductions 3 08-14-2012 09:27 PM
All times are GMT -7. The time now is 10:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
