Originally posted by MossyRocks
............. assuming a good calibration but calibration issues will show very quickly at 1500mm. ............
Something I found with regards to the tracking accuracy is that it is not the only thing that matters. It is also important to have a magnetically 'clean' environment. The calibration can only compensated for the local magnetic variations caused by the camera itself and anything directly attached to it, such as the lens and the quick release plate. Any other local variations cannot be accounted for and will result in an incorrect North.
The worst causes of such uncorrectable variations I have encountered are rebar in concrete structures, especially if standing on them such as on a building or even a concrete pavement and nearby cars. By nearby I mean within less than about 10 meters (30 feet) or so. Other hidden things such as buried steel pipes, metal fences and such can all through off the compass enough to cause significant trails.
Something that may also make a big difference is the tripod itself, or the telescope, as those obviously cannot participate in the calibration dance. Sometimes it could be easily fixable such as replacing some steel screws with brass ones if they are the only magnetic material but if there are other structural parts that are ferromagnetic it might not be possible to sort out.
Finally make sure to keep away any flashlights, cellphone, tablet or other electrical/electronic devices as even the small currents flowing through them can cause a detectable shift in the magnetic field around them. Some devices even have magnetic catches on their cover.
When I first used Astrotracer I struggled to get trail-less stars at long focal lengths until I started discovering what was interfering with it. Shooting from home is still impossible due to the rebar in the roof which i quickly figured out but out in the open it had taken me quite a while to discover first the bad influence the tripod was having and after fixing that (by using another tripod) I found that moving the car a bit further away from where I stood sorted it out and I could get one minute exposures without trails using my Sigma 150-500. I think by extrapolation one would be able to get minimal trails or with some luck not at all even at 2000mm if one is extra careful in avoiding any magnetic interference.
