Originally posted by pentaxian_tmb What should I be using for a custom white balance point? Big question is WTH do I do in processing to get the nice IR "negative" image instead of a red-washed one?
Base white balance off something green.
If you are after false-color IR, in general you will need to adjust the balance even further away from red. Then if you want the yellow-foliage-blue-skies look, you'll need to swap the red and blue channels.
I did some false-color IR at first, but it didn't take long before I found I prefer monochrome conversions for almost all the IR I shoot.
