Originally posted by Canada_Rockies One of the posters mentioned that he/she was worried about the card going bad because it is taken on and off the camera too often. Any troubles that resulted from this was because the camera was powered up when the card was removed. Removing and reseating devices with electrical contacts is a standard procedure to keep the contacts clean.
Good point. Also, it seems that if you're looking for things to worry about, I'd worry as much about constantly inserting an removing a USB cable. But that's not why I use a card reader - I do simply because it is easier, faster, and doesn't drain the batteries. Can't really see any advantage to using USB.
