Originally posted by creampuff That's because Peterson's book was first written during era of film cameras. With smaller sensor sizes of DSLRs today, the minimum aperture of lenses that can be used before noticeable diffraction is about 1 to 1.5 stops less than that of film. So if f/22 was acceptable for film, it is about f/11 or f/16 for APS-C. I think Bob Atkins wrote some article on this awhile back, or a simple Google search will provide you an explanation.
I think it also is a function of what lens!
As I posted earlier, the influence of difraction is a function of apature diameter. not F stop. F stop is the ratio of lens opening diameter to focal length. therefore F 22 on a 14mm lens is a whole lot smaller hole than F22 on a 50mm lens.
I am not so sure the ASP-c sensor format really adds anything other than forcing shorter focal length lenses for the same field of view, the impact of that is back to the fact that F22 on a 14mm lens is a smaller hole, hence defraction more important.
