11-20-2008, 11:00 AM   #1
247nino's Avatar
AF problem? K20D with 16-50 and other lenses
I was testing my setup today because I have a photoshoot later this afternoon.
I tried it with my 50-135 and 50 1.4 too... similar results... the only one that didnt do this was my 35 ltd
my test subject here is a little bud of some sort on the bush of some sort right outside the front door of my mother's house.
the picture I have attached was shot with my 16-50, @ 16 and opened...
the AF fired red *FOCUSED ON THE GROUP OF WHITE FLOWERS IN THE CENTER** and I followed through on the shutter release...
so I want to know if I am making an error, the camera/lens is making an error, or I need something different to test my AF... because it looks like everything around the flower was in focus but the camera "focused" on the white flowers...
Ive tried test charts and its a little hard to use a test chart @ 16mm focal length so I decided to use something real.
here is the picture. I will appreciate suggestions!!
thank you in advance!
view the exif data http://regex.info/exif.cgi?url=http%3A%2F%2Fimg508.imageshack.us%2Fimg508%2F...062testue9.jpg
download the large version MEGAUPLOAD - The leading online storage and file delivery service
11-20-2008, 03:27 PM   #2
Damn Brit
Guest
Looks like a little camera shake to me. Have you done this test on a tripod?
11-20-2008, 04:12 PM   #3
aleonx3's Avatar
Looks to me that you have BF/FF problem with that lens
I noticed that you are using center point AF, the sharpness however appears to be two third up the middle. You might want to try the test again using a larger object as your focus point and determine whether it is a backfocus or frontfocus problem. Since the shutter speed is 1/160, you should be able to lock in focus hand-held without any problem.
By the way, flowers coming out of the jade plant is very rear in this part of the country (i.e. true North - Canada).
11-20-2008, 05:41 PM   #4
Marc Sabatella's Avatar
You need to use a *much* less "busy" target. The center focus point is pretty large - realistically, it could have focused on just about anything there. The nice thing about focus charts is that they give the camera a completely unambiguous focus target, but yeah, wide angle lenses are tough to use that way.
But you'll need something similar - where there is nothing just above or to the side of the thing you are focusing on, but stuff further out toward the sides to check the results with.
11-21-2008, 02:53 AM   #5
247nino's Avatar
Thanks for the input guys,
Im thinkin that the bunch of flowers was indeed a busy target...
I dont think I had any focus problems...
just a bit of bad exposure once I tried shooting near some train tracks in total darkness.. even two flashes at full power couldnt give me the light I needed.
heres a sample from my shoot today, just a playful shot with my bicycle and my friend...
oh and one of me
11-21-2008, 09:52 AM   #6
yep, the focus area is bigger than a spot, your camera has focused perfectly on the area around the flowers. Try refocussing until it looks right in future.
af, camera, error, photography, picture, sort, test
K20d Problem Fl_Gulfer Pentax DSLR Discussion 41 10-18-2009 09:08 PM
k20d problem Neto Pentax DSLR Discussion 2 09-24-2009 02:59 AM
K20D Problem photoTaz Pentax DSLR Discussion 2 06-21-2009 09:25 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
K20D problem ariahspam Pentax DSLR Discussion 6 06-06-2008 12:10 PM
All times are GMT -7. The time now is 02:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
