Originally posted by FHPhotographer Sorry, but that runs contrary to just about everything I've read online about capture (input) sharpening, i.e., apply capture sharpening first to offset the camera anti-alias filtering, then amend the image, then use (if you need/want) either USM or Smart Sharpening at the end of the process for output sharpening. If you have come across a different workflow that works, please share it,
Brian
Sharpening should certainly be the last step if you resize for web and best results are if you do not sharpen prior to that point. However, if you keep the size it really should not matter and may be the first step.
My Photoshop workflow for web-sized images is as follows:
1) Tonal and color corrections, B&W conversion (no sharpening at this point);
2) Crop/rotate if necessary;
3) Resize to smaller size;
4) USM for local contrast (30-50px, 10-20%);
5) USM for edge sharpening (0.3-0.5px, 100-150%);
6) Add small border (just to separate image from the rest of the web page).
In Lightroom it is a bit different since you don't really control the order of adjustments so there is no right order of steps to follow but all adjustments are still there. (BTW, local contrast is called "Clarity" control in LR). For resizing, sharpening and adding borders I use LR/Morgify on "Export".
BTW, I have never heard or read about offseting anti-alias filter by sharpening. What is that? If you have any reference to it I'd like to take a look.
