I am looking for some quick tips as I need to take some effect pictures withint the next 2 hours. I googled and searched the forum here, but had no luck.
What I want to achieve: I want to pour a liquid and catch it as it free-flows through the air. This is a one-time thing, I cannot repeat it.
Now if I set my camera to single-shot (on a timer), this may be a hit-or-miss. Therefore, I want to try doing this with a continuous drive mode (high setting), and use a Flash. The flash should help with catching the fluid in a "frozen" state instead of getting a blurring effect that I'd have without the flash.
Now, here's the problem (I can use either a K-5, K-3 or K-1 II with a AF-540 or a Metz 48 AF-1):
If I enable drive mode on the camera, focus a fairly bright wall at arm's length, I'd expect that the flash would only use a small amount of its charge. Meaning I should be able to shoot 10 or more shots, each with with the flash lighting up. I did set the shooting mode to either X or P or A and chose the widest aperture (2.8). I tried a low (100) and high ISO (3200).
However, the effect is more like this:
The first 3-4 shots come with the flash, but at a rather slow rate (like 3 shots per second instead of the intended 8). And after that, the camera does a few shots without the flash, before it works again (even though I have set the "shutter release while flash is charging" to 1, i.e. off).
The flash is in the prism socket and uses P-TTL.
Any suggestions which settings I may be missing to get this working so that I get a high shooting frequency with the flash? Do I need to tell the flash to use less power somehow?
Actually: I just changed the flash to use A instead of TTL mode (and camera to X). Now, it does what I wanted. But why isn't this working with TTL? Is using A the "right way" to achieve this, or are there other ways, too?
