06-21-2021, 05:22 PM   #1
Star trails question?
Some star trail images are perfectly smooth and each trail has consistent brightness. Other trails vary in brightness and look pieced together. What causes this?
Thanks,
barondla
06-21-2021, 05:39 PM - 1 Like   #2
cdd29's Avatar
I'll try to take a stab at this (might be wrong). If you're talking about what I'm thinking of, where a star streak starts out dim and the trail gets brighter/wider, is done in Photoshop. I've not tried the technique but I read on it a few years ago but don't remember how it's done. Attached shot is for reference, not my work. If you're talking about brightness in general, streaks will vary in brightness depending on how bright the star is. The pieced together look could be due to gaps in exposures and stacking.
06-21-2021, 05:42 PM - 1 Like   #3
cdd29's Avatar
Related... here is a star trail technique (again, photo for reference not mine) I would like to know how to do, a vortex affect.
06-21-2021, 07:24 PM - 1 Like   #4
Aaron28's Avatar
QuoteOriginally posted by barondla Quote
being of consistent width, color n brightness is likely a normally stacked star trail
if the first example by @cdd29 is what you are referring to is generated in programs i use to stack the time lapse........with starstax it is called the comet effect which is a box that can be checked off to implement during the stack also there is a slider for short to long tails for the effect........with sequator the box gets checked that say motion producing similar results but short or long tail
QuoteOriginally posted by cdd29 Quote
not that i know or have done this but appears to be a twisted overlay from shooting north over a nice wide starfield
06-21-2021, 07:43 PM   #5
Yes, the comet effect is what I was trying to describe. Thank you.
---------- Post added 06-21-21 at 09:45 PM ----------
Neat effect. Not as "natural" as the other styles. I also wonder how it's achieved. Thanks.
---------- Post added 06-21-21 at 09:49 PM ----------
QuoteOriginally posted by Aaron28 Quote
Good to know the comet look can be achieved in Starstax. Guessing it can also make the continuous concentric rings?
I looked over a few star trail tutorials and never saw an explanation for the different styles.
Thanks for the info,
barondla
06-21-2021, 08:05 PM - 1 Like   #6
Aaron28's Avatar
as in the first example by cdd29 those rings are only achieved when set up looking at polaris (northstar) which appears stationary......more complete rings are made by much longer time lapse stacks............of course there is a central point in the southern hemisphere but in an area as there is not a specific star
see entry #9 for a diagram
How do I predict the arc of star trails?
06-21-2021, 08:21 PM - 1 Like   #7
Grimmus's Avatar
Thanks,
barondla
No ideas on the spirals but I recall seeing a YT tutorial somewhere.
As others have said, the software does it but if you want more control, you can adjust the exposure on the images you are going to stack in postprocessing, then stack normally to get tapered trails - one end or both ends of the star trail....like below. (this was about 72 minutes (36 frames) total with exposure adjusted on the first and last 9 frames to progressively reduce exposure 3.33 stops at each end).
06-21-2021, 08:57 PM - 1 Like   #8
Spiral is probably shot with a zoom lens which is slowly zoomed in or out during the exposure. The result is then combined with the foreground since the foreground can't be shot using the zoom effect. You would need a zoom which doesn't change focus during the zoom (parfocal zoom) and a way to zoom smoothly during the exposure (motorized by some means).
If your star trail vary in brightness, it could be caused by varying the lens aperture during the exposure (if done in a single time exposure for intentional purposes). Also, high clouds which might vary the brightness of the stars could be floating by which could result in variations.
06-22-2021, 12:24 AM - 1 Like   #9
QuoteOriginally posted by Bob 256 Quote
Great idea, I have to try that sometime. I guess this might work without motorization if I keep the exposure short enough to prevent star trails from happening in each frame and linking the stars of multiple exposures in post.
10-04-2021, 12:25 PM   #10
bobbotron's Avatar
Star stax has a setting that'll do the comet thing. Take a stack of images (try 50 or more, each 30 second exposures with a wide lens with your NR turned off). Feed it into star stax and hunt down the comet mode.
https://markus-enzweiler.de/software/starstax/
box, brightness, camera, comet, effect, look of star trails, photography, pm, reference, stack, star, star trails, styles, technique, thanks, trail, trails
Astro Need advice: Star Trails and Milky Way Wide Field Planned First Attempts jon.partsch Photographic Technique 26 06-26-2021 08:28 PM
Landscape First attempt @ star trails rtmarwitz Post Your Photos! 12 05-07-2021 04:22 AM
Thematic Post & Discuss Your Astro Tracer Star Trails & Star Shots wtlwdwgn Mini-Challenges, Games, and Photo Stories 48 02-22-2021 01:47 PM
Guidance for using bulb mode for star trails? Focusrite Photographic Technique 5 08-01-2020 06:23 PM
Night Seems like star trails are in vogue, and a bear story. Damn Brit Post Your Photos! 9 11-28-2009 06:07 PM
All times are GMT -7. The time now is 01:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
