Originally posted by Bruce Clark Also beware variable ND filters with wide angle lenses. These things are 2 polarizers and can create a darkened cross with WA lenses.
In my experience, the "dark cross" problem only occurs when both elements in the filter are circular polarisers.
With a circular polariser fitted to the lens first, then a linear polariser fitted on top, no "dark cross", similarly if both elements are linear
If you fit the linear polariser first, then the circular polariser, the whole concept doesn't seem to work … didn't bother to figure out why!
Obviously, with two rotating filters, getting the adjustment "just right" can be fiddly. I've gone to the extent of gluing one polariser so it won't rotate … if I just need a polariser I can still use the other one, but a scrap of adhesive tape would probably work just as well and not be quite so over-kill
