Originally posted by systemA I was going to make this exact same topic...then I did some practice shots with adjustments to the meter modes (matrix/center/spot) and figured out my problem. Post #4 addresses alot of what I was experiencing, and I've adjusted accordingly. Question I had, was if Nikon/Canon had the same "issues"?
depends on the model to a certain degree. Best to do searches at dpreviw and see for yourself. some Canon models for example had somewhat the opposite problem of over-bright base exposures. Many good outdoor photos had -EV dialed in.
This is a link to a gallery of some very nice photos w/ EXIF. short browsing shows EC in both directions but for the 350d and outdoor shots she has a -1/3 pretty much locked in...
IMG_0033s.jpg photo - Daniella T. photos at pbase.com
My take is it was necessary to contain highlights.
not sure if these were processed afterwards but she felt the need for negative EV, or other EV adjustments in the camera. Granted not as extreme as +/- 2 or something, but needed anyways.
As to Nikons, th base metering seems to have been different between some of the "consumer" and "pro" models, with the consumer models behaving like some Canon's and "overexposing".
Another thing I found was that Pentax base contrast seems particularily low. If you take an "underexposed" photo and do a "levels" adjustment it becomes a MUCH better picture.
On exposure:
'The exposure meter is calibrated to some clearly defined standards and the user needs to adjust his working method and his subject matter to these values. It does not help to suppose all kinds of assumptions that do not exist.'
Erwin Puts
On levels (even though Pentax can have some bunched up histograms it is still best to shift some w/ in camera EC but I personally am never discouraged by the darker ones because they are easily errr.. "fixed.) :
Levels and Curves - Photoshop Tips
As my own little tutorial on the power of levels w Pentax D files in particular. First photo is "as shot" w/ zero EC.
Second photo is a "sensitivity" adjustment which I assume for Pentax is exposure correction...
Third is just levels as you can see from the histogram.
