Originally posted by lmd91343 I tried the sunblock test and it failed. Obviously the sunblock is old and bad or one of the filters are bad.
I tried shining a 395nm flashlight at the unfiltered camera and it appeared as a specular white spot. I took unfiltered snaps and they all looked like images produced by other full spectrum cameras.
As for the Tiffen Hot Mirror filter, its specs indicate that it passes UV. Maybe mine is a counterfeit. A $70 counterfeit?
The UG1 might also be bad. It is opaque to visible light. But how to test it??
The UG1 is a filter which passes UV light but it also passes infrared light, hence the need for a "hot mirror" or a filter which should block infrared light and just allow UV to pass to the camera (the camera sensor is also sensitive to infrared light and you'd be recording a UV/IR image if the infrared is not blocked).
Here's the passband for a typical UV filter showing the infrared issue (see attached image along with a typical IR cutoff filter passband).
You can test your UV filter by shining your UV flashlight through it and see if a florescent material (like florescent orange or yellow) will give off visible light. It should allow the invisible UV light to pass and produce a bright florescence. Your eyeglasses would be expected to appear clear since normal glass is stated as being opaque to UV but that only applies further down in the UV spectrum and normal glass (especially plastic lenses which are used in a lot of sunglasses) is fairly transparent to UV in the 370-400nm range (UV A). UV B & C which is responsible for tanning and skin cancer has shorter wavelengths and is well blocked by regular glass. Tinted glass in cars is less transparent to UV as you might note in your photos. You can test your glasses the same way with the UV flashlight and see how much they dim the florescence when you put them in the UV light path. You can also test the sunblock by smearing a thin film of it on a piece of glass or transparent plastic and doing the same.
Note the shown curves would show results further to the left in the UV but the light source used for testing these filters was lacking in that range so the curves fade to noise.
