Originally posted by Rondec Honestly, I don't think there is any value to using pixel shift for objects that have a lot of movement or doing it hand held.
Hand held , you are right.
For moving subjects, my opinion differs slightly, depending on shutter speeds.... Let's take a shutter speed 1/10 second at ISO100 (lowest noise, best DR), camera on tripod, the scene contains moving elements and non-moving elements (breeze blowing through tree leaves and branches, or a waterfall), other parts of the scene don't move (tree trunks, rocks). Even without pixel shift, the moving elements won't be sharp at 1/10th shutter speed and won't show aliasing/false colors at the pixel level (looking at it on XXL print), the resolution is lost from motion due to shutter speed , regardless what camera / sensor resolution is used. For other areas of the scene that don't move , PS will at least lower the noise if there is no image detail. So if the camera is solidly fixed on tripod, pixel shift can only improve the image once all moving parts are excluded, the only downside is memory usage and waiting for the buffer to clear after 4 exposure PS. If I am not in hurry, I will make 1 PS exposure because I can always use only one of the 4 frames if PS makes no difference. Pixel shift is free :-)
