Almost a year passed, since I opened a thread looking for solutions to stitch seascape panoramas including waves in motion.
How to stitch panorama of waves - PentaxForums.com
There were some interesting ideas, mostly with compromises:
- either via long exposures to blur motion well enough so that stitches are seamless, limited to really slow shutter speeds
- or panning the camera really quick in burst mode, limited to really fast shutter speeds
- making a wide shoot with desired shutter speed to record the overall scene, and make a series of quick panoramic exposures for the details, merge frames with masking some areas of frames, revealing other areas
Possible but not ideal.
So I found a better solution. Since I happen to have two K1 bodies after getting a K1 II, I thought "what if I was firing the two cameras simultaneously?", cameras mounted side to side to capture two exposures, stitching images in post.
Pros of shooting two cameras simultaneously:
- No need to spend money, I already have the cameras and lenses (although I would prefer to match two 70-210 f4 lenses)
- Arca-swiss parts are relatively inexpensive for the assembly (at least compared to the price of cameras/lenses)
- Possibility to shoot squarish format, 4:3, 5:4, 1:1 , with one camera on top of the other, that would make a total frame of about ~40 mm x 36 mm
- Possibility to shoot extra wide, with camera side-by-side horizontal orientation, that would make a total frame of about ~60 mm x 24 mm , pretty cool 3:1 kinda X-PAN aspect ration in one shoot
- Possibility to use all camera modes regardless shooting situation (pixel shift, astro etc etc..)
Cons of shooting two cameras simultaneously:
- Heavy setup, tripod, arca-swiss rig, twice the weight of camera+lens, more gear to bring on location (but if the shoot is important, it can be worth the effort)
- Using ND/ND grad filters is a pain (requires two kits, one kit on each lens)
- Requires some time to adjust two cameras instead of adjusting settings for one camera only, need to adjust two lenses for field of view and focus
- Parallax error of near objects can cause problems for aligning frames, because side-by-side cameras can't be physically located at the same optical center.
Solving the problem with parallax error:
- I though of using mirrors at 90 degree angle, so that the cameras would be shooting from the same virtual point... but I gave up on this, turned out it's not possible theoretically, but... I haven't actually tried, so maybe my conclusion is wrong. Anyway, using two camera for a shoot would catch attention of people around, but that would be nothing in comparison with a dual camera setup with offset mirrors. So even if that would work in practice, it would need to be an Ansel Adams to do this kind of setup in public.
- So I decided I would only use one of the two cameras to capture the foreground, and shoot two cameras for the mid-ground and distant scenery
Solving the problem of simultaneous shutters:
- I experimented with the interval shooting mode of the K1s, programmed the same trig time in the interval settings. That didn't work because, to my best efforts to set camera clock at the exact same clock time, the cameras own clocks aren't in sync, easily firing up to one second apart.
- I also enabled the GPS with enable GPS clock sync, but I found that GPS clock time wasn't even exactly the same on both cameras (interesting, how can this be?) , plus the GPS clock sync doesn't seem to sync the camera clocks at all... so I gave up on this.
- I've tried to use my IR remote trigger, and it's able to trigger both camera shutters fairly close in time, within 1/10th of a second (according to the tests I've done) but, it's not 100% reliable, sometime each camera will not IR trigger at the same time. Plus IR doesn't work well or doesn't work at all if the camera IR sensors aren't next to each other, so it would require a mirror, practically bad.
- I've looked at using a camera cable release 2.5mm jack type (I don't have one, I'd have to buy one), yes, but I haven't found a "stereo" cable release able to trigger two cameras, and I've found a multi-camera trigger box online it can trigger many cameras within 0.0003 s. accuracy but it costs $2000 or something like that, I thought "forget about this".
- I thought about using radio triggers, now, the question would be if two radio receiver (one on each camera) can be paired to the same transceiver and trigger both camera shutters at the same time?
So, only way to go now is to DIY my own dual camera release cable. I've found some electronic schematic for Pentax 2.5mm jack release cable type, but.... unfortunately it doesn't say how the triggering works and if I can short together the contacts of both cameras or I need to make a set of two separate / insulated switches with common control. I have never even tried to use a cable release (I used IR), so I don't even know how much time lag and accuracy between two shutters there would be if I used a DIY "stereo" cable release. Anyone expert on this , advice would be welcome. Thanks.
Coz if I was able to trigger two K1 shutters at the exact same time, that would open up a lot of possibilities.
