Quote: still do not understand why the 'auto' shutter speed is limited to 1.3 where as the picture is all black and I do need to manually set it higher. I'm just trying to understand... I'm in my learning mode with the M mode.
this thread is confusing.. what do you mean by 'auto' shutter speed? in M, shutter speed is selected manually.
if you press the AE-L button to do stop down metering these are the slowest shutter speeds based on ISO & 1/2 EV setting. (k100D(s), k110D) if you are maxing out the shutter speed you either need to open up the aperture, set a higher ISO or get a faster lens. if you
want shutter speeds that long put the camera on a tripod.
200 = 1.5 sec. (yours is 1.3 because you are set to 1/3 EV stepping)
400 = 0.7
800 = 0.3
1600 = 8
3200 = 10
its important to keep in mind that although the camera can be used with manual lenses (and with great success) the meter wasn't designed for it. all I can really say is that pentax figured these max shutter speeds would be enough for stop down metering (and maintain proper exposure). you cant possibly get completely good results hand held at 1.5 seconds, even with SR so what does it matter? at that slow of a speed a tripod or some sort of stabilizer is a must for sharp as possible (or at all) photos.
