Originally posted by YJD Why is it limited to 1.3 second?
I've never heard of that happening, but if you're dealing with shutter speeds that slow, perhaps you're dealing with light levels below what the meter is capable of dealing with. Also, you realize there's no way to capture moving people with shutter speeds that slow? Not to mention no chance in hell of handholding successfully?
At ISO 1600 and the aperture wide open - f/2.8 - you should be getting speeds more like 1/30". There you'd have a fighting chance of getting a usable shot.
It shouldn't really take long at all to make the correct settings. Set ISO to 1600 the moment you take the camera out of the bag indoors. Set the aperture at f/2.8 the moment you mount the lens indoors. Do a test with the AE-L button on a medium-toned target to check the light. If it gives you a result faster than 1/30", thank whomever set up the lighting and start shooting. If it gives you a result slower than 1/30", sign and set the shutter to 1/30" and increase ISO to 3200 or just realize yu're gong to have to push the exposure in PP.
Then just start shooting. You shouldn't need to touch the ISO, aperture, or shutter speed again until you go outside. Unless maybe one room of the hosue is a lot brighter or dimmer than another, in which case you might turn the shutter speed up or down accordingly. Takes a fraction of a second - nothing you'd lose any shots over.
Quote: Any advice for my second question?
I am not sure I understand. Are you saying that at one aperture and ISO setting, a shutter speed of 1.3 seconds is too short but 1.6 seconds too long? There's not really a lot of difference between those shutter speeds - exercising finer control over exposure than that is something you would normally do in PP.
