Originally posted by ksparks519 I think the thing that was worrying me was my old manual 70-210 zoom lens. Zooming in, the aperture goes down a stop but the aperture blades themselves don't move
As pointed out above an f-stop is the ratio of focal length to aperture diameter (to be more accurate ...to "apparent" aperture diameter)
So on your variable aperture zoom, as you zoom from 70mm to 210mm, the widest available aperture will shift from being (as an example) f 4 to f 5.6. This can happen without the aperture physical size changing. Equally the slowest aperture available changes from say f22 to f32
Manual Variable aperture zooms often have a different index on the aperture ring which you should use when fully zoomed. Look at this picture. At 70mm you read the aperture using the long bold index line which reads f 11. But zoom the lens to 210mm and you need to use the smaller index line to the left, which is indicating f 16
