Originally posted by MossyRocks For doing star trails I am not a real big fan of intervolometers either built in or external as there is a delay between of 1 to a few seconds typically between shots. Depending on how point like the stars are and what focal length is used this may result in start and stops in the trails. You are correct in that they would allow for several minutes of exposure but in that case a bad single frame (god knows I have gotten a lot when out at night) would make a big gap in the trails.
100%. I can see the advantages in using continuous shooting and this is definitely a lower risk way of composing the trails. If something goes wrong with a frame, you only have to throw away 30 seconds, which will still leave a gap but may not be terminal for the image. It also gets rid of having to calculate or test to find the minimum interval you can adopt for saving the image if you use the internal intervalometer (except on the Kp where you can choose minimum). The stupidest thing I discovered while testing and making mistakes is that a 15 second exposure is actually 16 seconds and a 30 second exposure is actually 32 seconds ..... got lots of really gappy trails finding this out (why camera makers object to using the actual shutter duration escapes me?).
But you can make it work with the internal if you want and the question is really whether you want to risk a 30 second gap or a longer gap if a frame goes wrong - a lot of night stuff seems to end up with questions of risk and reward (and equipment procurement
The image below was with the K-3, you can't set minimum so the interval was set to 33 seconds and the shutter to 30 seconds (32 actual seconds) so produces a 1 second gap - which is pretty hard to spot at 100% (35 mm lens, f5.6, ISO800, 60 frames stacked).
