I think I'm one of the few PF members who actively posts sheet film shots from a view camera. It takes me a long time to focus for these setups. But I find them fun to do on rainy days when I'm itching to take some pictures.
The rear standard movement on a view camera is the most significant at geometry correction and other effects. The front rise on a tilt/sift lens mounted on say a SLR/DSLR to correct vertical convergence is a special case and not adaptable to as many situations as a view camera with rear standard movements.
Here are three examples of employing movements of the Schempflug effect to get deep DOF in a closeup shot.
Using a Caltar-S II MC 210mm lens:
Tools by
tuco, on Flickr
Schneider Symmar-S 180mm f5.6
Repeated Listening @ 33 1/3 RPM by
tuco, on Flickr
One rule of the Schempflug setup is taller objects need to be in the back of the scene because the DOF tapers from 'thin' in front to increasingly 'thicker' with distance.
CM Fujinon W 135/5.6
DIY by
tuco, on Flickr
Here, the rear standard was tilted to correct for vertical divergent lines and the front standard was rotated/tilted to match the front of the subject giving more effective DOF for only f8 on a 210mm lens (≈58mm on a FF) this close.
Mamiya C3 by
tuco, on Flickr
And again here using the same movements as above from a recent post:
Rodenstock apo-macro-sironar 180mm
Corkscrew by
tuco, on Flickr
Here the plane of focus was twisted until I got three parts of the scene in focus.
Apple Peeler by
tuco, on Flickr
Basic front tilt and rotation enough to encompass the shoes.
Legs and Feet by
tuco, on Flickr
And an easy one to focus
AKG Perception 200 by
tuco, on Flickr
