Originally posted by Erik Why would you think that? Not being confrontative, just asking. As far as I know, this type of result is exactly what hyperfocusing with a smallish aperture would give you.
I guess what I mean is...there is the DOF calculator, which tells you how much of the area in front and behind the image will be in focus.
Then there is the hyperfocal distance calculator.
I guee my question is, how are they related, which ones to use to get an image sharp from foreground to background.
Do, I use the DOF calculator and see where I focus to get the image sharp throughout (I assume this is at infinity focus, as when the calculator tells you 'infinity' for the area, that is in focus behind the focus plane) ?
or
Do I use the hyperfocal calculation to get the sharp image.
Which of the two ?, (or do both of these give the same result, ie when the dof calulation gives infinity focus that is hyperfocal distance ?)
or are there any other ways than these two?
Thanks
