Originally posted by madison_wi_gal Thanks. Nice what a bit of PP can do to a cruddy image.
Other than removing the foreground about all I did was crop out the sky, which I thought was MEH, and add a bunch of contrast.
I'm pretty shameless about photo manipulation. I have no problems with fixing it in Photoshop, though I try my hardest to not have to.
Also...
I suspect that f11 is smaller an aperture than will give sharpest results from that lens.
Here's an interesting exercise: take each of your lenses and photograph a newspaper page at every aperture. Check focus manually and don't refocus between shots.
If there is any focus shift from changing the aperture it will just be counted in with the result.
The idea is to know what aperture your lens starts to fail. The reason why is moot unless one stop down focusses, which will limit degradation to diffraction and will probably give a different result.
Now, look at each image and figure out the aperture it starts to go soft at.
After that, keep in mind that below that aperture you are starting to compromise sharpness and decide if you want to rethink your exposure settings.
