Originally posted by madison_wi_gal If I try to remember that I am an IT person vacationing with a camera
Your shots of the Crazy Horse Memorial and Mount Rushmore are an order of magnitude better than the shots I got in the summer of 2014. I'm going to post two shots from that vacation that hopefully will make the point that hard and fast rules should be ignored. Photography is a matter of first, seeing something you want to capture, second, quickly deciding on how you are going to capture what you see and third, using the results to guide your future photographic decisions. You will never get perfect results, but sometimes you get results that turn out better than expected and over time, unexpectedly good results will come more frequently.
Taken in Program mode, for whatever reason my camera decided f5.0 was going to be the aperture. I learned a long time ago that if you have something in the foreground that you want to feature, get it in focus and don't worry about the background. I do try to use hyperfocal distance with wide angle shots, but for normal and telephoto perspectives it just isn't worth the hassle. This is also an illustration why carrying a tripod with you might not be practical.
Taken at f10, detail and sharpness have more to do with natural contrast and light than your camera settings. I've cropped out half of the original 16MP image taken with the DA 18-135 at 135mm, but you can zoom in on it in Flickr and I won't be embarrassed.
