Originally posted by Wheatfield Anyone with a primary school education in mathematics should be able to figure that one out.
The logical fallacy is that math could be used to say 4 is less than 10, but a more agile mind may argue that we need to compare % of focal length change. If we do the difference between 20mm and 40mm should be proportionally the same as between 200mm and 400mm.
Using this logic is a 20mm vs. a 40mm the same as a 200mm vs. a 400mm? Let's agree the ratio is the same. 1/2 or 2x depending on the direction of the comparison. Looking at the angle of view the tale is a little more crooked...
Diagonal Angle of view (FF):
20mm = 94 degrees
40mm = 57 degrees
94/57=1.64
200mm = 12 degrees
400mm = 6.2 degrees
12/6.2 = 1.93
Clearly by this metric the 200/400 ratio is higher and proves well... not much. LOL. Lens focal lengths are often expressed in even numbers because that's what marketing people do. Pentax was weird and gave us the 43 and 31 and 77 - who else does that??? We aren't dealing with perfect numbers and the angle of view may be more accurate than the focal length.
In any case I think it is a useful way to point people to the right idea who might be new to photography but it isn't revolutionary by any means. Anyone with much time behind a lens knows that the focal length differences at the short end can be astounding while they are less easily noticed at the long end unless you are shooting very small objects like birds. And even then - the percentage of focal length not the absolute focal length is what starts to compete with angle of view as a metric.
