Luckily, I've had rather few problems learning photography thus far however, I've found myself with a bit of a lighting dilemma. You see, I've (tentatively) got my first paid gig doing a band photograph. My location of choice is a rather interesting hayloft that, thanks to the amount of snow around and the loose construction, lets in just enough natural light in just such a way that it makes for a very nice photograph. However, I imagine that I'm not going to get quite enough light on my subjects to make them distinguishable without ruining the ambiance. Of course, naturally, I want to add some light fill flash. However, my options are very limited seeing as the only flash equipment I own besides the pop-up on my K200D is an AF-16. I have access to two studio strobes with brollies and (if I recall correctly) a softbox. These would be almost perfect but... the electrical connections in the barn are less than safe for borrowed equipment, leaving me with only the option of battery-powered equipment. So, essentially what I need to know is: What's my most economical option here? My money's rather tight at the moment (the reason I've been trying to solicit gigs) and the most I can really spend is about $100. Below is a shot I took of just the loft. Settings are ISO1600 1/90s F/5.6 on DA 18-55.
Next inquiry:
I have a studio gig with my yearbook class next week taking portraits of grads. One thing I've noticed in my previous endeavours with studio flash photography is that I tend to get too much glare off of peoples glasses. The (admittedly faulty) setup we've used in the past consists of two strobes with silver brollies placed in a sort of long isosceles triangle with the subject covering the third point and the side formed by the strobes perpendicular to the backdrop. As I recall, one of the strobes can have a softbox attached to it. Both units react to the light emitted from the camera flash, thus I can't avoid using that (I'll probably be popping my AF-16 in just to get the light further away from the optical axis). I'll assume I'll want to use some sort of diffusion on that. Our editors prefer that all pictures have the subject facing the same way so I figure the most universally flattering configuration would be oblique, key parallel to the backdrop and fill perpendicular, but I'm a little lost on precise positions and which lighting accessories to use on which strobe. Also, if it will help I could possibly construct a makeshift diffuser with a bedsheet and some sort of frame. Any advice would really help.
Final inquiry (for tonight at least):
Does anyone have any experience with Hoya's Softon A filter? It sounds fairly useful but the
comparison images they use are all but beneficial to the product's appeal. The "with" image is extremely washed out. This seems to have been taken in daylight so I imagine that could have something to do with it. If so, does it behave any better in the studio? Or is it all bologna?
Thanks
