Originally posted by Gimbal Try this. Put on a manual lens, SR on, enter for instance 600mm. Set shutter to 4 seconds. Place the camera on a table and release the shutter (make sure SR engages) let go of camera.
With a little “luck” (it helps to give the camera a little twist when releasing the shutter) the camera starts to vibrate on the table
Just did a quick test with 250mm. I tried it with the camera on the table and halfway on the table (so that it could move like a seesaw). No movement by the camera at all. Yes, the sensor made a noise as usual with long exposures, but the camera remained rock solid. This was a K100D.
Well, I thought, you'll say it wasn't 600mm. So I went (can't believe I actually did this
) and got a manual lens. Set it to 800mm and 600mm. And *then* the camera really started to ... do nothing. Sat there as a rock.
When I gave it the tiniest tip, it started to wobble on the table. With the (smaller) manual lens it was in an unstable position, yet the sensor movement didn't cause any movement to it that was observable with the naked eye at all.
Interestingly, sometimes the SR would shut itself off. This was only the case when I pressed the release button without holding the camera, i.e., giving it a little twist when releasing. Perhaps -- pure speculation -- when the camera notices that it cannot counteract the movement, it stops SR altogether. Don't know.
Anyhow, no dancing K100D on my table. Now I'm disappointed.
I agree that movement should be kept to a minimum and I shut off SR on a tripod (better, I use 2-sec delay, which uses mirror lock up and shuts off the SR anyhow) but I'm not convinced that the noise I'm hearing indicates any significant
camera movement.
