03-28-2007, 02:08 AM   #1
skaktuss's Avatar
Dots. Can't get rid of them!
here is a sky picture @F22.
http://img292.imageshack.us/img292/5005/dotsus0.jpg
(i hope link works)
I cleaned sensor several times, but these dots stay. What could it be? Damaged sensor?
03-28-2007, 02:59 AM   #2
skaktuss's Avatar
Could you please post Your sky pictures?!
03-28-2007, 04:54 AM   #3
skaktuss's Avatar
Update:
After 5 more wet cleanings, I realized that specks are between sensor and low-pass filter! Damn! Now I'm realy mad!
03-28-2007, 05:35 AM   #4
QuoteOriginally posted by skaktuss Quote
Update:
I don't have any dust between the sensor and the low-pass filter. If you're right, I would consider that a manufacturing error and get a replacement. (Sorry!)
03-28-2007, 07:52 AM   #5
FotoPete's Avatar
Oh crap. maybe the fluid carried the dust into the filter before it evaporated. Try using a blow bulb dry. That usually gets dust off for me.
If its really stuck inbetween the filters...you should probably get it checked out.
03-28-2007, 12:21 PM   #6
Alvin's Avatar
Skaktuss, those definitely look like dust spots to me. Still, just as a sanity check, see if you can try a different lens to see if you get the spots in the same areas.
03-28-2007, 12:47 PM   #7
Good Idea Alvin. But if it is dust between the two sensors take it to a shop.
03-28-2007, 10:12 PM   #8
skaktuss's Avatar
QuoteOriginally posted by carpents Quote
Everything was clean, when I got camera. The only manufacturers fault is possibility to get dust behind filter. Why didn't they make hermetically sealed sensor?
QuoteOriginally posted by Alvin:
I tried other lenses. The spots are exactly in the same place.
QuoteOriginally posted by Photo Tramp:
It's not that easy. We dont have a pentax dealer in Latvia. I purchased camera from UK. There is Pentax cameras in shops, but waranty and repairing service is real PITA.
At wide apertures it is hard to notice these spots, almost impossible, but at F11 and up they are very observable on bright objects. And they are darker and more contrasting than dusts ON the filter.
I think I'll have to live with this problem, perhaps dusts are not sticked too hard and will drop out. If i had a scheme how to take apart this filter and camera...
camera, dots, photography, sensor
Thinking of getting rid of the DA*16-50?? HMM 68wSteve Pentax SLR Lens Discussion 3 01-30-2010 09:17 AM
Getting rid of the 16-50 to go to pancakes. Thoughts? herzzreh Pentax SLR Lens Discussion 33 01-05-2010 11:52 AM
Getting rid of noise. jbrowning Digital Processing, Software, and Printing 0 08-28-2008 08:55 AM
Getting rid of yellowing? How? jsherman999 Pentax SLR Lens Discussion 18 01-29-2008 05:34 PM
Get rid of the bird? Tom Lusk Post Your Photos! 15 09-26-2007 01:24 PM
All times are GMT -7. The time now is 09:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
