Originally posted by defiant From all these comments it looks like a lot of ppl manually set their digital camera's ISO to something higher than the lowest ISO (100 for my K20D), and almost always a multiple of 100. Is that only because it's something we're used to from the film days, or is there a technical benefit to do this for particular situations that isn't obvious to me?
Actually, 'film days' would mean you would have a *lot* of films rated to the third-of-a-stop, lots of 32 and 64 and 160 ASA-rated films, (And TXP at 320, while TX would be at 400,) Plus-X at 125, ...the early fast color films were 1000, not to mention you'd often choose to rate a film bit under or over, ... lots of use for those thirds-and-half-stops on the dial. (You could as easily say the *round* numbers are the ones that are a third of a stop away from whatever your 'standard' is, really,)
I've been wondering if there's really any practical use in digital, ...apart from consistency with meters or films, where it's convenient to keep everything in full-stop multiples of each other, particularly when dealing with elaborate lighting, (like mixing Vericolor II and TXP, for instance)
Is there a hidden 'sweet spot' at, say, ISO 640 on a given camera? No idea. Something I've sort of wondered about.
