Originally posted by julianactive I don't see why shooting RAW has anything to do with bracketing. RAW can't do miracles with underexposed or overexposed shots. If that was the case then why even bother with exposure?
I shoot mostly manual and RAW plus JPEG. I have found very little difference with the end product for what I shoot, so I have been thinking of doing away with my RAW setting for most of my shots. To me RAW seems to be of the greatest value for changing white balance. Now when I shoot indoors I think RAW is the way to go.
You can use one RAW file to generate several exposures, and then blend these together to increase the dynamic range, i.e. post-process bracketing. This is very useful if you for instance don't have a tripod with you.
A RAW shot can also let you recover some highlights that would be lost in a JPEG file, or let you bring out
some detail from the shadows with less noise than you could with a JPEG file. So actually a RAW file
can do miracles in some cases, it has saved my shots many times.
