02-23-2009, 04:08 AM   #1
What's wrong with my camera?
I hope this is coherant enough to understand. I took some benadryl just before I noticed this, so I'm a bit woozy.
My problem is almost impossible, if not impossible to spot in the Flickr link, even in large size. If there is a way to somehow display the way it looks at 100+ percent before converting it to JPEG, please let me know, because that would work much better.
There are spots in the picture, I noticed them in a few recent photos, so I went back to check my older photos to see if they were in them too...they were.
Where some of them are on the picture of the VW.
1 - Just under the H in "Michelin" on the passenger side front tire - Red.
2 - Just under and to the left of where that first one is - Blue.
3 - In the chrome above the passener side headlight - Blue
4 - Inner wheel well, rear passenger side - Green.
Some observations about the spots.
1 - In the exact same locations over the course of consecutive photos, but varying from photo set to phot set, which is usually day to day.
2 - When viewing the RAW file with the Pentax software, at 200%, each spot will look like a little red, blue, or green plus sign, with a slightly blurred area around it.
3 - Hard to notice the spot when it's in a very bright portion of the photo.
Cleaning the lens doesn't seem to affect the spots(Lens pen, with dust brush, then rubbing with pad). I say cleaning doesn't "seem" to affect the spots, because it's always possible that using a different method might affect them.
What doesn't affect the spots.
1-changing memory card.
2-turning off, then turning on.
3-Focal length
4-Aperature
5-ISO setting
6-Asking politely for it to stop this silly behavior
Unfortunately I can't try a different lens, because I don't have a different lens.
Camera = K110
Lens = Kit lens
I do realize I can get rid of them in post fairly easily with cloning, but I don't want them in the pictures in the first place if it can be helped.
Thanks all,
Justin
02-23-2009, 04:35 AM   #2
MoiVous's Avatar
This sounds like hot pixels. Test it by shooting an image of something with a uniform colour across the image - eg the sky. If the pixels pop up in the same places then its your sensor and hot pixels.
I'm not sure if you can map them out on a K110D - you can on a K20D and K200D
There are quite a few threads about it as well - search for pixel mapping
You could also do a crop to show the pixels in question and post them for more detailed opinion....
Good luck......
02-23-2009, 06:43 AM   #3
Wheatfield's Avatar
I can't see what you are talking about in your picture, but you are talking about hot pixels.
They happen, get used to it.
Get a decent RAW converter that maps them out.
Photoshop's converter removes them.
02-23-2009, 07:58 AM   #4
Lowell Goudge's Avatar
if yopu want to show what you are talking about, perhaps crop in on one spot, such as the one on the tire (I can't see it but I will believe you it is there) and post the cropped section at 100%.
In Jpeg they probably look like a cross, with the center pixel the brightest, and the top and sides a little dimmer.
You can use pixel mapping or noise reduction to eliminate them.
I use the blemish remover tool in PSP X2 to take them out of my *istD photos. I have not seen any (yet ) on my K10D
02-23-2009, 10:58 AM   #5
Thanks everyone
I google image searched "hot pixel", and what came up is exactly what I'm seeing in my pictures. I'll look into using a different RAW converter, or mapping them out.
Apparently it isn't anything new, and every camera has it to a certain extent.
Thank you very much, I have the day off today, and without your help I would have been worrying about this instead of enjoying a day of shooting.
camera, day, lens, passenger, photo, photography, photos, picture, spot, spots
K-7 In camera noise reduction startiung at iso 3200? (Wrong forum) pcarfan Pentax SLR Lens Discussion 0 08-16-2009 05:32 AM
K20d, still hotpixel issue with jpegs or something wrong with my camera? Karn Pentax DSLR Discussion 9 08-09-2008 03:33 PM
What is wrong with the camera stores of this place? deudeu Photographic Technique 5 07-05-2008 07:07 PM
3 artistic shots. Sorry 2 from the wrong camera little laker Post Your Photos! 6 02-04-2008 10:25 AM
All times are GMT -7. The time now is 06:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
