What you do sounds pretty much like the norm for me as well...only without the disappointment part. (I have such an ego
) Each photo session translates to hours of computer time finishing the creative process. What we see in the LCD is only a sampling of what potential has actually been captured. This is particularly true when shooting RAW. The real magic happens in the post-processing. The process is truly analogous to the flow with film:
Image Capture- Compose and expose to fit the lighting and your visualization of the final image
- Check the preview rendering in the LCD
- Check the histogram in light of the desired exposure range
- Repeat steps 1-3 as needed keeping each exposure (just in case)
Post-Processing (...they don't call it Lightroom for nothing...)
This phase is essentially the same as what used to happen in the darkroom way back when. When done properly, it is possible to work miracles. (Though those are always worked within the limitations of the original capture...yes, it pays to shoot RAW...)
- Import the image into the software of choice using the default settings
- Adjust brightness, contrast, and color balance to suit
- Add/remove sharpness
- Apply noise reduction (if needed)
- Crop to suit
- Proof (remove imperfections) to suit
Printing
This last step is the most difficult since all of the work to this point has been done using a luminescent image (additive colors). Printing involves translation of the image formed of light with one formed from differential absorption of light (subtractive color). It is at this step that we lose much of the process control and where there is the highest potential of losing the magic quality that makes a particular photo a winner. The options?
- Print them yourself and run through gallons of ink/dye and reams of photo print paper
- Work with the printmeister at the local camera store
- Work with an expensive custom print maker
Do these all sound expensive? Well, it is! I guess that explains why many of us (most?) don't make a lot of prints! I received a digital picture frame for Christmas and now I can display my work without the hard copy
