I had always thought that TC's will not allow for higher magnification at the closest focus distance, as I had imagined the focus distance will increase with the TC effectively cancelling the lens magnification. I was experimenting with shorting an M42 mount so that the AFA will auto focus. During those testing I found the focus distance of my Volna-9 didn't change with the afa adapter and gave me a magnified image.
So, why not use the 1.7 AFA as a macro extension tube (more like a macro helical converter).
Also, even though I got the afa to Auto focus with my M42 lens, it is not metering well and I have lost SR. Any suggestions ? (I shorted all the pins on the mount, can I do this selelctively to save SR and metering, thank you).
Now some sample images of the M42 1:2 macro lens alone and with the 1.7 AFA. (The lens is the Volna-9)
Volna-9 at F2.8 at the closest focus distance.
Volna-9 with 1.7 AFA at F4 and at the closest focus distance.
So, isn't this essentially what an extension tube does, OR am I missing something ? Other than the extension tube does it with no lens element by moving the lens away from the sensor, and the AFA does it with lens elements and magnification.
I like this better, as the lens is a 85mm lens now, so the bugs will be less scared. The only possible drawback over ext. tubes is IQ loss due to lens elements, but I think the 1.7 AFA adapter does well here...
The 100% crop with the 1.7 AFA and F4
P.S: I destroyed the lens element of a TC and made a 25mm extension tube, and took this shot for comparision. Even with thetripod and f16 (max) I missed the focus, the top of the image is much sharper.
