Originally posted by dlacouture Now, concerning the PK-m lenses, I read somewhere an useful trick : drill a second locking hole before the original one in order to lock the lens partway in the mount, so the aperture actuator doesn't push yet the aperture lever of the lens... This way, the lens will work like a m42, but will still be able to function as before if you use the original locking hole instead of the new one... Pretty neat, huh?
Indeed! Plus, if the "A" contact is made & you e-dial in f1.2, the camera does P-TTL ok regardless of where the aperture is preset.
It is like an m42 regarding aperture and uses P-TTL for flash. I tried it and it works ok.
Might it be worthwhile altering the camera mount so it thinks all lenses have "A" capability? That way, K lenses with the extra pin-lock-hole can use P-TTL too.
I may try this to make using my m42's useful with P-TTL (I have no actual K's.)
Iowa Dave
