Originally posted by crbrune Back in 1967 I shot LeMans and the German Grand Prix. I was able to lay on the edge of each track as the cars came by about 10 feet from my head. I got some great shots, but take my advice, don't do that...! I was young and foolish. In these long races, just keep shooting and try everything that comes to mind. The delete button is your friend.
wow
and I feel nuts getting in a runoff area with a 400mm lens
And that brings up a point, if you are not familiar with race tracks, ask a driver / organizer where the runoff areas are, and avoid them like the plague. You can get plenty close as long as you know where it is safe to do so and more importantly, where it is not safe to do so.
Ohh, and always carry a course map with North/South marked so you know where you are and where the light will be before you make a trek to the next corner. I would suggest marking gates/entry points you can use, and make sure the turns are numbered or named, if you point and say "that turn over there" you will confuse all of the drivers and trackworkers.
