Originally posted by pingflood Sure, you can spend a small fortune on things to direct/block the light, but I bet there are some good inexpensive and portable ways to do it too.
For example...
(credit where credit is due - I learned the following from reading Master Lighting Guide for Portrait Photographers. Good book with lots of examples and setups)
Foamcore board is good for more than mounting prints. The
non-acidfree stuff costs $10 for a 40x60" sheet at Hobby Lobby. It's pure white (the acidfree type is a bit dingy) and light as a feather. It makes a great bounce card or reflector. And if you spray paint one side flat black you've got a gobo. Take two sheets and tape a hinge along the long side of them and you've got a "bookend" you can use for a plethora of light controlling options: block it, bounce it, focus it, feather it.
Now grab two more cans of spray paint, gold and silver, and put a light coat of each on opposite sides of the 2nd sheet of your bookend. Now you've got a 40x60" 4-way reflector for about $35 in supplies (try pricing a retail reflector that size online
And of course you don't have to go 40x60 either. You can cut up a big sheet into smaller ones or just buy precut in smaller sizes (but the big sheets are less expensive per sqft). A 20x30 card is big enough for bouncing the sun to add fill light on an outdoor shoot and will fit easily into
most trunks (or boots depending where you are). You can make four of those from one big sheet. If you bust one up or lose it, so what it only cost you $5 to make.
Here's a really basic example of using the bookend:
The setup: Vivitar 285HV @ 1/4 power into 17x50 strip softbox. Fill - 40x60" foamcore "bookend".
I really needed to either bring the bookend or the softbox in closer to balance the light as the fill is a bit weak here.
