Originally posted by larrycook99 Oren, I am surprised when you said that you use flash to shoot horses. Do you use an on-camera flash? And if so, it doesn't bother the horses? I ask because my son rides and I have shot pictures of him while he is at his weekly lesson but never considered using a flash because I was afraid of spooking the horse.
On camera flash does not throw the light far enough. You could use it for close up's but it's only the more powerful flash units that can throw flash any distance. One of my lecturers has the Canon 580EX. In some cases they throw the light enough to light up a football pitch apparently. That'd be used for long distance shots.
I fired off a BAZ flash a few times two weeks ago when doing equine portraiture at close range. Horse about two metres away. However it was broad daylight and his back was to the sun (had to be lit by flash as I was metering for the background) and he seemed ok with it and handled it. In a place where it is already lit or during the day, it's not as noticeable as to say if you were to creep up on a horse in a dark stable and fire one off I suppose - like anything else because even the majority of human beings would be spooked by someone firing a powerful flash in the dark unexpectedly and they're intelligent enough to figure out the source of the light and what it is causing it. An animal is not. In fact the horse that I dealt with was so fascinated by my camera and the noise he actually came closer to investigate touching it with his nose at one point. That's how close I was. He's not a show horse so not use to anyone waving a camera around. He's more of a hunter and supposedly...not friendly.
