Originally posted by SuperAkuma (snip) My main concern is the compatibility of Pentax gear with studio lighting. I am enrolled in a photography class right now but we are working with film only right now. As time progress we will work more with digital and studio lighting. I am not sure how the class studio is setup like what brands/type of lighting that it uses. (snip)
Wheatfield and MRRiley are both correct about hotshoe adapters and wireless triggers, but that isn't going to help much with the studio lighting in your class. What you need to do (in advance) is find out exactly what is used to trigger the lights in that classroom. The best way to do that is to stop by the classroom with your Pentax (between classes or after hours) and ask the instructor if your camera is compatible with whatever device is being used to trigger the lights.
If the class will be using a wireless setup, will the triggering device provided fit your camera's hotshoe and trigger the lights? If the class will be using a wired setup, will the hot shoe adapter provided fit your Pentax? If not, you'll need to purchase the hotshoe adapter (with x-sync socket) or wireless triggering device (the compatible transmitter for your camera) yourself. This is why you need to check this out in advance.
With the necessary triggering device attached, there is no reason whatsoever why your Pentax wouldn't be sufficient for the class. The studio strobes themselves are manual devices (no TTL automation), so any camera with a manual mode (you set shutter speed, aperture, and other settings) will work in that regard.
One further note, since the classroom will likely be Canon and Nikon centric, you'll need to study up on your camera's manual mode before attending the class (don't expect the instructor to know anything specific about your camera). Also make sure to bring your owners manual to the classroom in case the instructor must refer to it when answering any questions you might have.
stewart
By the way, since both Wheatfield and MRRiley mentioned the Pocket Wizards, let me add a plug for my favorite wireless triggers. My studio uses the Elinchrom EL-Skyport universal radio slave set, which is much cheaper than Pocket Wizards and just as reliable (made by a major studio strobe manufacturer). And, like the Pocket Wizards, this particular Elinchrom radio slave set will work with any studio strobes.
