Originally posted by OregonJim You can't get a valid white balance through the filter. You also can't use the meter to calculate exposure. What sort of exposure times have you been using? Usually, you'll need to be in the "several seconds" range. You will always get the red tint unless you physically remove the internal IR blocking filter and replace it with a hot mirror filter (either internally or on the lens). But then your camera will only be good for infrared - no more "normal" pictures. Most people reduce the image to B&W before PP.
From browsing over IR threads here I was under the impression that it was possible to simply use the R72 filter. I do not want to go completely IR at this time. Was I wrong?
I have been calculating the exposure by framing the scene and setting the aperature to f8+. I then would change the shutter speed to net me +1 or so exposure. after I had that set, I would slip on the filter and press the shutter release.
Here is an example of what I am getting consistently with this method:
ISO 200, 20mm, 1/4s shutter speed, f11, auto WB.
I came across a blog that had similar issues with the red channel and his solution was to pull a custom WB of green through the IR filter (which prompted my question)
