Originally posted by res3567 You dont use flash, I presume?
Correct. In most of the settings where I shoot, it would be completely unacceptable etiquette-wise, plus it usually ruins whatever lighting effects are going on.
Quote: How are your images when it comes to noise at iso1600?
I'm satisfied with the results. I was already happy with the DS, and on upgrading to the K200D I find it does at least as well. It's noisier if you use the extra pixels (10MP versus 6MP) as an excuse to blow it up bigger, but when comparing images at the same size, they are quite comparable. And since the K200D starts off with more resolution, that gives me more leeway in terms of being able to apply heavy NR if I choose (although I rarely do). Since I'm starting off with more detail, I can afford to lose more through the NR process. So I can choose between not doing much NR and getting pictures that are more detailed than the DS and about the same in terms of noise, or else use more NR on the K200D and get pictures that are about the same in terms of detail as with the DS but noticeably cleaner.
I've posted various examples in other threads, but since I haven't done so in this thread, here's one in which I shot one full stop underexposed at ISO 1600 and pushed it in PP - yielding the equivalent of ISO 3200. I did only minimal NR - mostly trying to keep detail. Here's a link to a reasonably large resized (not cropped) version:
http://marcsabatella.zenfolio.com/img/v7/p548058206.jpg
By comparing it to whatever you're used to at that size, you should get a pretty good of how much noise there is. I think it's as good as I have any right to expect ISO 3200 to be. Especially since most of my shots are viewed on the web or printed relatively small. At the size I am posting below, you'd have a real hard time seeing any noise at all:
