Originally posted by Squier You could spot cheese on the moon surface with that
Not quite, to capture the cheese you need a 400mm (16 inch diameter) scope.
Alas I only have a 200mm diameter f10 telescope. With a 3x Barlow I photograph the Moon and Planets at 6000mm Focal Length. With just a $160 web cam I have images of features that are 500 meters wide at a distance of 386,000 kilometers.
Speaking of yellow, the Moon does have some subtle color and so I would not use monochrome. I read an article about those who push up the saturation to find large blue and yellow areas on the Moon plus a bright yellow spot. This is not "false color" but emphasized color.
I just found this one on the net:
Moon - high saturation: Photo by Photographer Peter Dove - photo.net
Squier:
That is a very good Moon shot especially for someone starting out.
