A quick update for the pervs following this thread: It looks like the 47B filter (passes only UV-violet-blue light) on the K20D does a good job of bringing back that old-timey look. I did a spotty bit of RAW+JPG shooting the last few days, and I have some preliminary results to talk about. I haven't had time yet to work on the images, and might not for a few days, so y'all will just have to wait.
Exposure-mode and focus are critical. What doesn't work with a 47B filter: AF (there's not enough light for the K20D to autofocus with any accuracy); the viewfinder (too dim); P-mode (extreme EV adjustments are needed); color.
What works: Set the digital filter (Custom Image) to B&W-blue. Use LiveView and manual focus. If the CI isn't set, you'll hardly see anything on the LCD screen or viewfinder. (The UV-pass filter
newarts mentioned above probably wouldn't be usable, as even the 47B passes very little visible light.) Use Av-mode (and watch the ISO climb) or M-mode (and shoot slow). Focus manually. Hope.
I sloppily cut that flimsy Wratten gel filter for a 49mm ring, so the fastest lenses I can use it on are a 28/2.8 (DOF isn't very shallow), 37/2.8, 50/1.4, 85/2, 135/3.5, and 200/5.6 (sharp but not too fast). I'll likely give a 40-80/2.8-4 a whirl too, maybe with a 180 fisheye - that should be weird enough. I've so far only tried the 28 and 50, just enough to build those preliminary DoWork/Don'tWork lists. Now it's time to take all those lenses somewhere interesting and do some semi-serious test-shooting. Stay tuned for further developments.
Note: I also tried the 47B on my 'NightShot' Sony V1. The mix of UV and IR is definitely odd, but I can't say that it 'works', at least not for anything resembling reality. But reality is over-rated, right?
EDIT:
Iowa Dave, thanks so much for generating those graphs! I'll have to look for a spectrometer and gen a chart for the 47B filter - or I'll cheat and point to the chart here:
http://newportglass.com/kodak/kod47B.htm - Adorama has a 75x75mm 47B for US$14 here:
http://www.adorama.com/LEB47B3.html which could be easily trimmed to fit most lenses. (Hint: cut the get filter to just fit within a lens' front ring, then screw in a lens hood to hold it in place.) I think a combination of the 47B and selecting the Blue channel, should give a full effect. Maybe a lighter CC filter, like the fairly common (and cheap) 80A or 80B, to block/most some of the Green and Red, and using the Blue channel, would also be effective, without cutting the light so many stops. That could make autofocus more feasible. I'll try that out Real Soon Now.
Originally posted by OregonJim The easiest way is probably with a reusable a bulk-load cartridge.
Ah, bulk-loading. I gave away my darkroom gear, including bulk carts and changing bag, back around 1992, when I thought I'd forsaken chemical photography forever. What a
FOOL I was! Gave it all to a girl and never even got kissed. [Slams head against wall.] But wait, an idea comes to me! [Slams head again.] Ah yes! I just received a Sprocket Hole Revolution 135-620 adapter set, a couple pieces of whittled wood -- which I used as templates for crafting 135-120 adapters from a dried-out plastic felt-tip pen. I can easily fit a 135 cart backwards into my 120 Zeiss Ikonta-B folder, or the 620 Ansco Panda brownie or Anscoflex TLR. Now I can get sprocket holes AND diffused color-shifted reversed-emulsion images, all in one! BONUS: The Anscoflex was designed by Raymond Loewy, creator of many rounded-edge Modern products, so I'll look especially Hip while using it. Holgaroiders got nothing on me! (Holgaroid - that sounds like a nasty medical condition. Ewww...)
