Originally posted by rparmar There is no sign the K-7 will have better IQ than the K20D, though it will have more noise reduction modes to blur out detail, like Canons do. And it will have lots of in-camera tricks like HDR... all of which are better done on the computer where you have more control and a much larger monitor.
I agree. For the kind of photography I do, I don't care about in-camera noise reduction at all. Perhaps I should try it out, though. If it's good enough it might save me some time.
Quote: The reduced size is also greatly exaggerated. It's only 50g lighter, for goodness sake.
Not a big draw for me. I rather like the size of the K20D and like it even better with the grip. Just feels right. I don't like using the *ist DS because it's so small. I understand that this is a matter of personal preference. I also understand that smaller cameras are less intimidating to subjects - but as you say, the K7 doesn't look MUCH smaller.
Quote: So I see no compelling reason to upgrade from a K20D, unless you really need video or some other non-photography frill. If you are a machine-gunner the faster frame rate is a draw. If you can't hold a camera straight and can't use Photoshop the built-in level is nice. If you only use JPG and digital lenses then the CA removal will save you a few minutes on the few shots that ever require it. And so it goes.
None of this matters to me at all. Would rather NOT have to pay for video capability.
Quote: I don't care about a better display since no image should be judged on the LCD. A better LCD only tempts those who don't know any better into thinking they are looking at their photo. The panel on the K20D is already fine for the purpose.
Disagree with you here, though. I would have said this until the other day when I saw the display on the Canon 50D, which I think is comparable to the display on the K7. The K7's display isn't just an incremental improvement over the K20D, the way the K20D was an incremental improvement over the K10D. The K7's display is bigger and MUCH higher res. I think it will be useful to me when I need to check to see, for example, if a photo of the bride's wedding ring really is tack sharp. I do agree that you won't know for sure until it's on the computer. And the truth is that I keep instant review OFF most of the time. But there are definitely times when I would find it very useful - useful enough that if I had more money in the bank I'd buy the K7 for this alone.
Quote: Two significant improvements are the quieter shutter and faster shutter speed. I also like the fact the focal plane is marked. That's a nice touch.
Also very useful features to me. I've always thought that the shutter noise is a disadvantage of DSLRs. I shoot a lot in churches and if I could shoot noiselessly, I would love to. I like the fact that the weather-sealing on the Pentax K10D/K20D mutes the shutter noise somewhat. If the K7 is even quieter, that's an advantage in my book.
Don't care much about the faster shutter speed or the faster FPS. Don't think I've ever taken a picture at 1/8000th sec. I might use faster FPS occasionally and wouldn't complain about having it - it's just not a big deal for me.
Quote: But still no back ISO wheel in "M" mode, a crippled mount, poorer SD card compartment latch, reduced viewfinder magnification, removed bracketing button and so on.
I didn't realize the bracketing button is gone. I use that not often but occasionally. I assume the K7 can bracket, yes? You just have to dig into the menu?
What's "reduced viewfinder magnification" mean?
Will
