Originally posted by ytterbium Have there been tries to fabricate and position microlenses in such way that you dont need any more lenses?
So that each microlens has such amount of offset in required dirrection it projects required image part on the pixel. This could potentially allow for extreme aperture ultra wide distortionless imaging, because you need to project good image only on one pixel (per lens).
I brought up this idea in my early days on PFC, (mis)labeling it as "affective optics". The structure would be similiar to a planar affective antenna array, composed of numerous small elements that are electronically 'tuned' and 'aimed' by varying phase relationships of control voltages - thus the planar antenna can be of any effective wavelength and aimed in almost any direction without any physical movement or changes.
Optically, we'd have our pixel-site array, each site with a floating microlens that can be magnetically 'focused' and 'aimed' to sit at the desired angle and distance from the pixel site. The entire array would act as a 3D interferometer, effectively with any desired focal length, aperture, and aim. Such an affective 'lens' could, without itself moving, track and focus on any objects within its 180-degree field of view (although it's effective FOV would more likely be closer to 155-165 degrees).
That's the theory (or wild-eyed-fantasy, at least). I'd be surprised if NOBODY was trying to design and build such, but I have no idea who or where, or if they'd reveal anything about it. Talk about trade secrets! And commercial implications! Such would shut down the optical glass factories and design studios. And could lead to a total surveillance society.
Imagine: here's a chip that can 'be' a 1-100k mm zoom, f/0.1-100k, total AF and SR/IS, for any format from pinhead-PNS to 1x2KM, still or video, any spectral slice, etc. It wouldn't be necessary to fabricate huge chips for large formats, just tie together as many as you want in an array (it's an interferometer, remember) - and the linked array needn't even be flat, so you could have a cam-ball with total 360-degree vision. A rather small cam-ball, even. You think this might be handy for surveillance and spying? Ya, I suspect much development work is ongoing.
