Originally posted by vandamro Hi Folks,
I live in England and the weather really gives lots of subdued outdoor lighting. Even when you can see the sun, mostly cloudy is the norm. My problem is that I'm getting photos with rather drab results.
Can you guys suggest how to improve my camera technique to compensate. I use a Pentax K20D. I've been experimenting with the following:
1.) Using a warming filter
2.) Pushing up the temperature on the white balance.
3.) Using the "cloudy" white balance setting but that really doesn't help much.
4.) Experimenting with the image mode (e.g. vibrant, bright, natural etc.)
I really would like to get nice punchy, saturated colors.
Thoughts?
1) Warming Filter
Depending on the type of overcast, it can already be quite warm, unless it is really dark. I find some of my best mid day shots are with high overcast, colors seem to pop out.
Really dark overcast is just that, however, and as others have suggested, perhaps you should consider that in the "mood" of the shots you take, at the risk of being labelled by your friends as depressing.
2)& 3) WB adjust
I don't understand the comment here pushing up the temperature makes them colder, more blue and depressing, and it sounds like you already have that. To warm up the photos you need to reduce the color temperature (i know it is backwards but...)
if the K20D WB adjustment is like the K10D, have you experimented with the settings fully. On the K10D, if you take a shot, then select Fn And WB you see the image you just took, and it changes interactively as you adjust the WB. You can really fine tune it this way, and although the display is not "calibrated" it gets you very close.
4) Experiment with image mode
I change the contrast and image mode all the time based upon the contrast of the scene and how I want to shoot. at maximum contrast my K10D has only 4 stops in the linear region of the histogram between 25 and 225, but at minimum contrast it has 6. that is two additional stops of dynamic range for bright days, but on a cloudy day where things are a little flat, increase the contrast to spread things out a little. Look at your histogram to see how wide it is at the base. if it is really narrow, you can increase contrast and saturation. if it is really wide, you may wish to reduce contrast and saturation.
