Originally posted by Jodokast96 No, you aren't quite getting it. Go back to Canada Rockies last post. He explains it perfectly. By exposing to the right, that doesn't necessarily mean you are pushing it up by any Ev value. It's easy to think that it would, and in some cases it may be true, but it's not an absolute. It's all about what part of your shot you are exposing for. All exposing to the right pretty much means is to expose for the shadows, and maybe push it a little bit more. This will reduce shadow noise when brought back down, instead of exposing for the entire scene, and then pushing the shadows if needed. Are you getting what I'm saying?
Then I still fail to understand that argument, I believe however that you do not get the point I'm trying to make in the original post.
Let me try again.
Since there no other means available to get any higher Ev than
shutterspeed and
aperture, getting your histogram to the right as canadian_rocky says, you'd either need to slow your shutterspeed or to open your aperture, or both.
However, that is not what you want (see original post). That is why you got yourself at that high ISO in the first place. There is no other means than those two, except for increasing ISO even further...
I agree with Pingflood, that if you are at any ISO (except for your lowest perhaps) you may get better results (may it be shadow detail [what I have seen] / or less noise [what I have not seen]), but choosing a higher ISO value and applying ETTR.
There is also in camera noise generation besides the sensor (cross talk being one of them, the one that is the main source of "banding"). So in both settings the result in detail and noise output may differ a little.
I understand very well the idea of ETTR and I can follow the logic, but it is not complete. Still I believe that you are misled.
Jeff Kroll has given an excellent explanation of the mechanics of a camera system.
ISO gain change will not change the amount of light captured by the sensor, it will only increase signal gain before it is digitized.
So, in order to increase the sensors s/n ratio (worst in low signal / dark areas), the only thing you can do is to increase the light captured.
But that is not what you wanted because your lens is 200mm, it is a handheld shot and you want to maintain some DOF!
And of course in a high ISO setting adding more light to the sensor will create a right positioned histogram. But then effectively nothing has changed. Except for the highlight clipping loss due to digital multiplication of the signal.
- Bert
