Originally posted by Sailor Thanks, guys. I think you're right. I just ran another experiment: I printed from the Pentax browser to see if PSPX might be the culprit. As it turns out, the Pentax bowser prints from the "opposite" end of the landscape compared with PSPX. The streaks are there and show up in the same place on the paper but on the opposite side of the image. Curiously, I've printed other photos over the past couple of days - some with dark, rich colors - and the streaks can't be found, no matter how hard I look.
Thanks again,
Jer
Get some Epson Matte Heavyweight photo paper. Cut to size if necessary. Run the print head cleaning cycle. Do the nozzle check on the matte paper. It will check the nozzles and soak-up any excess ink on rollers, head, whatever.
Don't run light or high-key images right after dark or low-key images. Keep the printer level when ever cartridges are installed/present.
If you have used this printer for a long time, the head may be worn-out--duty cycles for desktop ink jets printing photos are less than 1/3 the typical sheet count specified by a manufacturer.
