Originally posted by LeeRunge Bob,
I just recently joined this forum while doing research and deciding on a Pentax system. I found this entire thread highly interesting. I was in the Army as well (2003-2007) and flew unmanned aircraft. The portion about taking pictures for aerial maps was interesting to me as most of that is done via satellite or uav these days. I went through Fort Sill in 2003 and probably navigated the same land nav course you mentioned earlier in the thread.
I have been through Iraq 2005-06 and I am in Afghanistan right now as a civilian (same job).
When you mentioned air assaults coming in and jumping off the rails from a moving helicopter, I couldn't imagine doing that with all the armor I wore while active. My body armor with front/back/side and arm protectors weighed @ 45 pounds alone and with rifle and ammo and helmet you are carrying 60 pounds let alone a pack it very quickly hits 100 pounds. The Iraqi's asked if we had cooling pills so we wouldn't overheat with all that gear on. Although I think Vietnam was worse for heat as humidity is miserable, the middle east is a dry heat.
War has changed so much and it is a conversation in itself to describe how robotic it has become finding the enemy. Most soldiers have pocket cameras today but the military is savvy to the power of a photograph and you must be conscientious as to what you photograph.
Thank you for taking the time to scan and upload your pictures they are a glimpse from the past in an honest manor.
LeeRunge,
Ya' made some interesting observations and comments here! You need to remember that in my unit B Trp 1/9th, we were primarily doing scouting and recon missions. If you look at the photos closely, you'll note that
none of our guys were carrying anything more than our web belt, suspenders, and and occasional "ass pack". If we were going to be there for an "extended stay", our lift crews snagged up our rucksacks and flew them to us as a re-supply mission.
The only "body armor" available back then were what we called "flack jackets" and they were pretty much useless in my mind (never wore the damned thing). Due to our primary function, we tende to travel light, although we did carry a larger basic load of ammo than the conventional infantry troops.
It was only for that reason that we could jump from moving helicopters at 12 to 15 ft if necessary!
The heat and humidity in SE Asia is absolutely
brutal! I can't even imagine trying to function with all the crap those guys carry nowadays.
You mentioned the NEW ID Cards having an RFID chip .... does that mean they don't have "dog tags" anymore?
Your final comment about being "robotic" in finding the enemy is indeed a whole subject in itself. Your brain becomes so focused on a single goal, that everything else seems to fade away. Focusing, setting apertures, shutter speeds, all the other "technical stuff" about shooting pictures back then became an instinctive thing. I'd often be waking thru some of the "triple canopy jungle" and find myself changing shutter speeds, aperture, hyperfocal distance, etc. all while looking for that "next shot".
It's really strange how the mind functions in that kind of environment .... hell, ya' do stuff without even thinking about it! Given the circumstances of combat, I guess that's a "good thing".
