Originally posted by Kornbread Even though this is the first time you have asked this, I will still grace you with a response.
uno: post #11 "
"i am more intrested in WHY the OP got the idea that he has to start out with manual mode, when the greatest teaching tool at his disposal is the instant histogram.""
dos: post #19
"define "steping up", this confuses me, greatly."
tres: post #22
"i'm going to ask for a third time, why are you
assuming that going manual is going to "move you to the next level".
Originally posted by Kornbread Simple. More control,
more control over what? in Av and Tv mode, you "control" 2 of the 3 variables, and the third variable is selected for you by the cameras metering system, most often than not giving you proper results
by going into manual, you gain no benefit under normal circumstances, you are just increasing the time effort needed to do the exact same thing (ie, "meter")
Originally posted by Kornbread a better understanding of my camera functions,.
by going manual you are not going to learn anything about "functions", since you are taking away any automation the camera provides you with, you are in essence "not using any functions"
Originally posted by Kornbread and a better understanding of proper exposure (in various lighting conditions). As a bonus, I really like to learn new things.
understanding exposure, is a concept that could be learned without ever touching a camera.
applying exposure concepts to derive photographic images, requires the use of a camera, by using 3 variables to caputre said correct exposure
but as i mentioned many times, you have to arrive at that "correct exposure" by use of some sort of light meter, and in modern cameras going into M mode yields no real benefit.
Originally posted by Kornbread Do you use manual mode? Why?
i use M mode for specific instances of flash photography, however this is mostly due to the flashes fault more so than the camera
and long exposure night shots, where the meter simply cant figure out what to do.
also when i want to brake any photographic conventions and just do something whacky, in which case i need to brake the meter, and going into M mode is the only way.
Also, you need to be in M mode for some old lenses, but thats a different issue all together.
