Originally posted by Lowell Goudge no the histogram shows the final captured image, if you used exposure compensation this will be factored into the image
I don't know about that? I'm no expert but this is what was happening to me. I am only shooting in RAW format and this should only work with RAW format not if you shoot in JPG format.
I would go out shoot some shots that looked good on both the histogram and the image displayed on my camera lcd.
I would load those images up on my computer and they would all be a lot darker with not much detail.
Did some research that said the histogram you see on your camera is a/the JPG image. Taking in all the camera settings (contrast, brightness, sharpness...). But the RAW image is just that a RAW image that is not effected by the camera settings. Only the JPG images are affected by those. It's like trying to use the in camera filters in RAW format. The camera will not let you.
I checked it out with my images. Those images before I changed my camera had a histogram on the camera that was not the same as what I had on my computer. Once I changed my camera settings and moved all of them to the far left, not just zeroed them out. My histograms on the camera match the histograms I am getting on my computer almost exactly.
This is on a K100D. The newer cameras might be different. Try it out on your camera and see what you get. But once I changed my camera settings I have not had a problem with exposure when I download them onto my computer. Before that every shot I took was different.
Bob
