I also posted the same thread on another Pentax forum.
In the Hyper-Program mode, you are in total control of all the steps. You can manually change the aperture with the rear e-dial (default).
Changing the aperture makes the camera switch to an
aperture priority automatic exposure. The shutter speed will be adjusted accordingly. If the shutter speed cannot accommodate the brightness, the shutter speed will blink in the viewfinder and on the LCD panel. While changing the aperture, the aperture is underlined in the viewfinder.
You can manually change the shutter speed with the front e-dial (default). Changing the shutter speed makes the camera switch to a
shutter priority automatic exposure. The aperture will be adjusted accordingly. If the aperture cannot accommodate the brightness, the aperture will blink in the viewfinder and on the LCD panel. While changing the shutter speed, the shutter speed is underlined in the viewfinder.
You can return to automatic exposure
Green Mode at any time by pressing the green button located beside the shutter release.
With the Firmware update Version 1.10, pressing the OK button will show the ISO setting and while keeping the OK button pressed, the ISO setting can be also be changed with the front e-dial. Note that the ISO will not be reset with the green button. Changing the ISO really puts the camera in
Sensitivity priority.
This mode could be the only mode available on the K10D and it would still be a wonderful camera. You make the decisions; the camera adjusts to your commands. If it could only cook!
When using a lens with an aperture ring, set the aperture to the “A” position.
In addition, you can use the EV compensation button.
You can also use the Exposure Bracket Mode with up to 5 different exposure in increments of 1/2 or 1/3 EV.
You can use the Extended Bracket mode along with the Exposure Bracket mode,or by itself. That would give you up to three additional exposures for each shot of one of the following; White Balance, Saturation, Sharpness, and contrast.
Finally, you can use all manual lenses in that mode, in the same way that you do in the
Manual mode.
It seems to me that you can do everything that you can do in other modes with the (P) mode alone.
Surely, I'm missing somethinh here.
Yvon Bourque
k10dbook home
