05-15-2007, 06:14 PM   #1
MShawn63's Avatar
Correct Exposure on the Beach
When I shoot pictures of my kids at the beach the shots are always to bright. Any suggestions on how I can adjust for this within the camera?
Thanks
05-15-2007, 06:24 PM   #2
Dr_Watso's Avatar
QuoteOriginally posted by MShawn63 Quote
Thanks
Well, depending on how you go about it, that could be a lengthy response, so I'll suggest that your "exposure compensation" function would probably be one of the quicker ways to do something proactive about it...
05-15-2007, 06:27 PM   #3
I typically will dial in minus EV from .5 to 1.0 in high light conditions. It really depends a lot on the overall light and subject matter.
Surprisingly, in film days, the tendency was more toward under exposure rather than over.
Another problem I have discovered with my K10 is that in high ambient light when I am chimping, otherwise good exposures look too light to me. Then, after I adjust accordingly, I later find that the origonal exposure was more correct. Not always but more often than not.
Walt
05-15-2007, 06:49 PM   #4
khardur's Avatar
well, the forum was being updated so I just repeated the above two posters.
another suggestion would be to try the "snow/surf" mode in the scene program.
(but check your histogram to be sure you're really overexposing those shots - on my K110D, even turning the LCD brightness down, it looks too bright to me - but the histogram tells a different story..
I also use the "show bright portion" option, so the blown out highlights blink when the image is shown on the LCD screen - then I know for sure what's blown out and what still has detail.
05-16-2007, 01:23 AM   #5
QuoteOriginally posted by newtmaker Quote
Walt
i have the same experience as yours. i guess the LCD in the k100d adds some .5 or .7 EV to the actual exposure, or the actual camera itself underexposes, as what you said about the film cameras. that's why i've learned, just recently, to slightly overexpose my images in the camera so that when i transfer it on lightroom or photoshop the exposure would be correct.
05-16-2007, 04:15 AM   #6
Try taking your meter reading from the sunny blue sky
If you don't already own it, I highly recommend you purchase Understanding Exposure by Brian Peterson.
05-16-2007, 10:03 AM   #7
MShawn63's Avatar
Thanks for all the responses. I'll be doing my shooting with my K10D this year vice using my *istD. I'll try setting the .EV and seeing what that looks like. Gotta love the flexibility with digital to be able to see the results so quickly.
MPrince, I do have the book Understanding Exposure, I'll have to re-read it.
Thanks again
05-16-2007, 05:26 PM   #8
Arpe's Avatar
That's funny, if i leave the cam on auto my beach/snow photos are always too dark as the camera sees a bright image and stops down. I dial in a + (plus) compensation, not - (minus) .
05-16-2007, 06:05 PM   #9
MShawn63's Avatar
Arpe,
I get the exact opposite. I'm always fighting the suns reflection off the ocean and the sand trying to get the correct exposure. I'm going to bring a polarizing filter to see if that makes a difference..
Shawn
05-17-2007, 05:19 PM   #10
Arpe's Avatar
That should help.
05-17-2007, 05:25 PM   #11
Lowell Goudge's Avatar
I have to agree with Dan.
use the histogram, look at the shots, and adjust only your exposure compensation with the histogram in mind.
Using the display is very misleading and is prone to error due to ambient light.
the other way to look at things, especially with the K10 is to set the over/under exposure warning on, on the display. it shows red for over exposure and you can see what highlights are burned out
beach, camera, photography
peterson's "correct exposure" Deiberson Photographic Technique 3 09-21-2010 08:58 AM
K-x correct exposure indicator. boosted03gti Pentax DSLR Discussion 12 04-27-2010 04:16 PM
Main Beach, Laguna Beach, CA TonyD Monthly Photo Contests 0 01-06-2010 10:31 AM
What constitutes correct exposure? photog Pentax DSLR Discussion 29 10-01-2009 06:53 PM
K10d - what are my options for correct exposure with manual lenses? Steve Beswick Pentax DSLR Discussion 34 07-08-2009 10:51 AM
All times are GMT -7. The time now is 05:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
